TC Rear Output Leaking
Michigan/Costa Rica
I'm getting some oil leakage from the vicinity of the rear output shaft of the TC. My first thought was that the rear seal needed to be replaced, however, taking a closer look, it appears that the oil is seeping from inside the flange, between the flange and the u-joint. To leak from this area, it seams that the oil would have to travel between the output yoke and the output shaft. Looking at the FSM, I don't see any seal or o-ring that would seal this area.
Has anyone encountered this problem? Any suggestions?
Thanks in advance.
