TC / Drive shaft question
Afton VA
I just did some searching in the FAQ and tech but didn’t find exactly what I was looking for.
I’m swapping in a SM465/3spd in my 78 40 and I’m trying to verify that I can just bolt on a companion flange and drum brake from a 4 spd TC to be able to use the 4spd drive shafts.
Is this correct?
Thanks all
Yes, on the rear.
The frt output changes to finespline about 1/78, so the coarse spline 77-earlier t-case will not accept the flange off the 78 t-case. The easy workaround is pull the d-shafts apart at the slip, then slide the 3-speed stub end into the 4-speed tube. This may be a necessity to clear the big 465 tranny anyway.
420’s have the reverse gear on the passenger side that creates fitment issues with the larger four speed drive shaft components. The 465 is tapered on both sides and there is plenty of room.
:beer:
Looks like I need a course splined 4sp companion flange and a 4spd brake drum.
This is going over to the “wanted parts” section. I’m hoping to get the SM465 and 3spd TC assembled together before tearing into my rig.
If anyone has these parts in good condition, send me a PM.
Thanks again!
