TBI adapter design?
Da UP, eh...
Website
www.trailcarnage.com
I am designing my TBI to 2F adapter now. My carb insulator is junk so I am goin to build the adapter in (2) pieces. The lower will replace the insulator. The upper will mount to the lower and the throttle body will mount to it. I have a question about the fuel/air flow. Attatched is a screenshot of the patterns that I have developed. The light blue shows the 2F insulator pattern and the magenta shows the throttle body pattern. You can see that there a three patterns. One show both cirular patterns. The second show the 2F bore pattern turned into a slot. The final shows the TBI bore pattern turened into a slot. The question is: what pattern would lend for the best flow? Consider that the cirular patterns would blend into the slots. The other idea is to run both patterns as slots. Although, I would like to keep the TBI pattern as circles so there is material to suppoet the gasket. Any thoughts would be greatly appreciatted!
~Tom
I am by no means an expert.
It seems to me the best flow would be a combination of pics 2 and 3 but you would have to make a custom gasket.
You might see is spaceghost has any more of his adapter plates too.
Two comments.
1. The plenum created by the slot in either case will add to top end (a misnomer for the f/2f) and take away from low speed throttle response. Bad idea. Use 1 piece of billet. Set it up in the drill press/ milling machine for a 15 degree angle from vertical (aka 75 degree) and drill out the bores leaving plenty of of gasket surface between the bores. blend with the die grinder as needed. Use a tbi shaped spacer as an insulator if you want.
2. The downey adapter turns the throttle body 90 degrees for clearance issues. make sure your setup will clear with the air intake you choose to use.
I have checked with SG. He has none at this time, bummer. When you refer combining 2 and 3, are you refering to having a slotted, tapered from the TBI to the manifold? That is what I was thinking but I was unsure as the carb. insulator seemed to be tuned(the through holes were different diameters).
