TBI 350 stumble.
Utah
I've been helping my friend work on her truck for a whiles.
Engine is a TBI 350 from a 1990 GMC 'shortbus'.
Currently, the truck idles great.
Get in to drive it, and it runs fine as long as I keep my foot out of the throttle. The second I punch it, the engine will rev 500 rpms more than it was then it will stumble. Kind of like it hits the rev limiter. However, this happens at any rpm. 1500 rpm, punch it, it goes to 2000 then it drops off to 1000 rpm (about). 3000 rpms, punch it, it goes to 3500 then stumbles back to 2500 rpms (about).
Initially, I thought it was a problem with the Throttle Position Sensor. We swapped that out, and are getting the same problem
Then I figured it wasn't running in open loop mode, and we swapped out the o2 sensor. It actually wouldn't idle properly at that point and made the problem worse.
FWIW, We've already checked or replaced:
MAP sensor
Coolant temp sensor,
fuel pump
alternator
battery
ECM (gm 8747)
fuel filter
IAC solenoid
Ignition module
distributor signal generator coil
checked all vacuum lines
I am stumped on this one.
GM TBI Gurus any ideas?
Thanks!
Bump to top.
If this really is a noob question please let me know.
This thing is driving us NUTS.
Tiger...
I am not going to be much help, but I'll toss my first though out there.
What about the fuel pump? Doesn't TBI require a little more pressure than carbs? Maybe the fuel pump is not putting out enough pressure for the system to operate? I know my buddy runs a quart sized fuel filter to keep plenty of fuel pressurized and available for his TBI.
awp_cruiser said:
Tiger...
Yeah it does require more pressure.
This has a fuel pump that was recommended by Howell, specifically for this applicatoin.
It's 2 months old.
Made by Holley.
I have wanted to get a fuel pressure gauge and test the fp.
Perhaps we should jsut to check our butts.
One more thought.
Kate installed a Kill switch which disconnects the battery power from the rest of the system.
Could the ECM be 'forgetting' the settings it's learning?
Or are teh ECM's that 'smart'???
Thanks!
