That serpentine setup looks good but, just wondering if the cost is worth it in the long run? Will a setup from a Outdoor parts warehouse (junkyard) from a 350 match up to a 283? they are both small blocks and several parts interchange, just wondering if this will?
I've put a number of different serp belt systems on cruisers.
The ones that come on the astro and G-vans are one big stamped steel bracket. The ones that come on a lot of the trucks and cars are two aluminum castings.
The aluminum ones flex less and look nicer, not that I really give a damn what they look like. Both have a A/C compressor, but there was an option package that used an idler pulley instead. I've never seen one in person though.
You MUST use a water pump from a later small block. The serp belt causes it to rotate backwards. The serp pulleys have a different bolt pattern on the water pump too. You could probably make a serp pulley work on a V belt pump, but it wouldn't cool right.
A serp system is nice. The belt is easy to change. It is under the correct tension all of the time. The belt doesn't get loose. It is much wider and seems to have better contact with the pulleys, especially when it has a lot of wrap around. When something seizes you're done, though. You can't limp home with no p/s or no alternator, because you will also have no water pump.
The alternators are generally much more powerful than a V-belt alternator. Most V-belts were in the 35 amp range, about the same as a cruiser. Most serp alternators start around 65A. Mine is a 105A. It cooked the stock wiring to the amp gauge. I ran straight to the battery and use a volt meter.
On a 283 you don't have the option, I believe. I think, and I could be wrong here, but the 283 does not have the three tapped holes on each head that ANY of the stock serp belt systems need to mount up.
The system on my T-100 has the aluminum brackets like my64's, but I don't have that little idler between the crank and AC. I'll have to look at it tomorrow and see what's there instead. I got it off of a Olds Custom Cruiser Vista wagon.
