taurus fan on sbc
slc area
Just finished installing the Taurus 3.8 electric fan behind my stock radiator with a 350. Didn't have a chance to drive around yet but at idle, for about 25 min, the needle on temp guage didn't even come close to the first white marker line :) For about a year now I've been fighting this stupid heating up issue. I'd heat up just sitting and idling, on the freeway, just cruising around town, and easily heat up wheelin'. Started looking around on this website about a month ago for solutions and found the 'taurus fan' idea. Found the fan and shroud for $20 at the local junkyard and still trying to put together the wiring ordeal(just tested directly to the battery for that 25 minutes in 90 degree heat at idle). I'm stoked to finally be able to get her back out on the trails where she belongs. :D
The donor Taurus was an '89, I believe. The important thing here is that the fan is from the 3.8 liter V6 motor. Late 80's and early 90's IIRC will have these fans. It almost mounts up PERFECTLY to the stock radiator, I think there were three matching mounting holes already on the fan shroud. Than just did some minor modifying to get two more. Still trying to figure out the wiring schematics that have been posted. I suck at wiring and understanding wiring. Any help on this?? In just plain english please :)
could you post some pics or email tehm too me? jeffspicolli350@yahoo.com . i have been having this same overheating problem with mine and this seems like a cheaap fix. thanks . as far as wiring the only way i know how to do it is to get the thermostat switch the goes kinda where the thermo stat is and it puts power to teh fan ata certain temp. or if you are really lazy and want very simple wire it to the run position on your ignition switch si it is always on when the car is on
I have a 2 speed taurus fan on my FJ with a 300 HP 350 and a 4 row radiator. I had to go to a 180 thermostat from a 160 because it was running at 150 going down the road. I have been able to get the temperature past 195 since. I have a painless wiring temp switch for the fan. I believe it turns on at 185 and off at about 175. Great fan, really sucks some air. I just have it hooked up to the high speed. BTW, the 4row radiator is much much better than the 2row aluminum ones that are supposed to be so good.
