Talk me down from the ledge...
Los Angeles, CA
I am getting frustrated with my 80, every time I go to fix something, the next thing breaks...
I recently took my 80 in for an oil change, and tire rotation. It is a pain where i live to dispose of the oil, so I suck it up and have my oil changed at the dealer.
They are familiar with my truck, and it should be a no brainer, RIGHT?
Well, after 3 1/2 HOURS they finally finished the oil change, after almost running my truck through the car wash with the sunroof open (I caught that, not them) I headed home. I will say they did comp the whole job, so that wasn't bad. Still not worth my time.
I get home and the parking brake is binding, a problem I had known about, but as long as you didn't use the brake it would not act up. I have been planning on rebuilding it, but have not had the time.
SO back to the dealer I go... $500 later I have the parking brake fixed... finally picking up the truck on tuesday, and returning the free rental.
My dilemma is this... I need to do the axle seals and I am scared out of my mind. If I tear them apart and need bearings, or inner seals, I'm gonna loose it.
I am considering getting rid of her and getting something I can obtain parts for easier and taking less time to work on it.
Please remind me why this is all worth it.
Don't sweat this. Cruisers are very resilient and often fix themselves.
Anyway, there is no doubt you need to do a knuckle job and replace the knuckle bearings and axle seals. This is NORMAL.
Unfortunately, it's just one of those jobs you must do yourself. No one trying to make money will take the time to do it right and get all the details right. I promise you the dealer and anyone else unfamiliar with Land Cruisers will 1) do the job wrong, and 2) Charge an insane amount to fawk it up.
Read up a bit, order some parts from Cruiserdan, and set aside a weekend to knock this out. Not a big deal, considering you have one of the best vehicles ever made.
Well the question is first, how do y ou drive your truck? This would most likely determine the advice you are given. If you don't off road your truck much and it doesn't see too much action then there are things you can do to make your life easier. For oil changes get one of those easy drain lever attachments that goes into the oil drain plug. Capture oil and put it into a larger 5 gallon pail or larger drum. Worry about it once every year or so instead of every oil change. The oil filter itself is pretty easy to take off, relatively speaking.
The parking brake is something that you could have fixed yourself just using the info found on the site. It was one of those things I was going to do myself but learned it wasn't an issue. I just had bad rear brakes.
When you say axle seals, are you saying for front or rear? Rears are cake and the bearings rarely fail from what I've read on this board. Fronts are another animal. Give yourself the time to replace and as a matter of PM just replace the races and bearings regardless if they are needed or not. Do it once and don't worry about it for a very long time.
You mentioned getting parts, CDan is great at getting everything and shipping out pretty quick.
Its all worth it depending on your usage.
I hear ya, my LC is 17 years old, and there was a time about 4 years ago when I was gonna dump it. Your ride is 12 years old, so I bet your feeling the same way I did a while back. I was stuck with my truck because of a new baby, lost job, and my first home. I just kept driving it, hoping it would die, things kept breaking or stop working, but the damn thing just wouldn't die.
Now, after many long hours of fixing things, it runs better than the day I bought it. It has passed my "try and beat it to death" test, and I'm glad I have it. I do have to say that I have spent years aquiring my tools and abilities to just tear in there and fix whats wrong, if you can't work on it yourself, it doesn't matter what 12 year old truck you have, its gonna cost you.
FSM, we don't need no stinking FSM:cheers:
My .02 cents, which are worth about .01 cents these days....plus I am only about 20 posts from Newbie status...
First off, I have owned mine for 6-7 years, I have 209000 miles and it is a daily driver. Some days I love it, others I hate it. When something breaks and I can't drive it, I just park it until I can fix it or afford to have it fixed. When I hear about the cash for clunkers...I think maybe....but then, why saddle myself with a 4-6 year loan for an electronic POS that I will never be able to fix? Let alone the fact that my LC will get shredded. Screw them, I am going to make as much CO2 as I can afford!
Having the shop fix it was killing me so I started to do things myself this year. I am mechanically inclined but inexperienced, but I have learned to change and flush the coolant, track down electrical problems, even took off the back of the transfer case and removed my seized Viscous coupler and put it back together. Nothing like some of these guys on here, but learning, and I haven't been able to screw it up too bad.
I think the biggest thing though is that it is a tank.I have been under some more 'modern' cars, my wife's Chevy 3500 and my old vette, and i would put my frame up against any of them. When my kids are in it, I know that even though it needs a little body work and a face lift (currently a wood front bumper....don't ask), I am pretty sure we are protected.
So, bottom line, get yourself a back up, change is good for the soul, but keep your Cruiser.:cheers:
Slow down...... first off do you know or hang out with any FL cruiser heads???
If so they can help or guide you in the front axle rebuild..... might be worth visiting the FL forum here on mud-----make friends.
Then again..... sit down with some free time & read the MANY post about how the job is done & what's involved........ honestly if you have high milage...... plan on replacing the bearings while in there. This $$$ can be offset by purchaing the parts from Cruiser Dan:idea:
Slow down drink a :beer: and remember the cruiser in the long run will cost less to maintain & own vs. a $$$$ a month payment plus the PM cost.
You are looking for reliability in a 12 year old truck. Relatively speaking the cruisers are very reliable - but compared to new hardware they will not be. You seem reluctant to wrench - this is going to weigh heavily against the cruiser which is going to need help to conquer the next 12 years.
Take a look at your maintenance costs currently - take a look at what a new vehicle is going to cost - do the math. For me the cruiser is way cheaper than a new car - but I wrench everything myself.
thanks guys, this has been very difficult for me, since I use this for a daily, and don't off road it (I have a jeep, don't string me up), i will motor along keeping the LC.
No reason to punish my 80 for the previous owner's mistakes.
I will find the time to do the front axles, going to order races and bearings today.
Hopefully this will cover everything I need for awhile...
I'll post more as I finish.
I refuse to let this beat me. I love the LC.
X2 on finding a local club. From what I read here on 'Mud, CDan is a good resource for obtaining parts. But don't overlook your local dealer. True, most will not always give you their best price up front or have the specific vehicle knowledge Dan does, but there is a good chance they will give you a decent deal if they are connected with your local club. I have not run across too many businesses that will turn away a group that is willing to give them their loyalty. There are at least four dealers here in the Phoenix metro area that give anywhere from a 20 to 30 percent discount to the various Toyota/Scion/Lexus owners/enthusiast groups. Nothing against CDan, but if you need a part ASAP, and it's on the shelf at the local dealer, and they're willing to cut you a break on price, I say buy local. Especially if that dealer is a sponsor of your local club.
CDan has gotten many a paycheck from me over the last few months... He is amazing, and I will be calling him today for the bearings and races.
As for the local club, the FL cruisers are mostly 45's not 80's.
I am a member, but get little feedback from the club.
Sounds like someone needs to get an 80 based club started.
Do your own oil change and take the old oil here:
AutoZone
812 E State Road 434, Longwood - (407) 830-5237
They have a big ass red container to poor it into.
