I've been using the 5w-40 Rotella T since I got my 80 almost 2 yrs ago, but this oil change I went to Mobil1.
Is this normal? I do 5k mi oil changes nd the 80 is my DD. The Rotella is fine until roughly 3500 miles, then my consumption skyrockets. I might use 1/2 qt - 1 qt up to 3500 mi, then over the next 1500 I've needed to add 2+ quarts. I check the oil diligently and have a leak that might leave one dime-size spot a week, if that. No smoke or other indications of any oil-related problems. Everything else is perfectly normal, all maintenance is up to date, and the 80 runs great.
I don't have an oil analysis b/c evidently Blackstone has ignored my requests for a kit. Thus I am left with the theory that the Rotella is breaking down and shearing as it ages. The very unscientific oil pressure gauge also starts showing wide fluctuations at idle <--> higher rpms as I approach 5k miles on the oil, whereas it is more "steady" when the oil has 0 to ~2500 mi.
Mine has never been that low since I've owned it, but it was at least 2 or 3 quarts low and blacker than tar when I bought it from the PO (and no oil light was on). I mainly used mobil 1 synthetic for the first 2 years and I would have about a quart burned between oil changes at 3500miles. I just switched to Rotella, but I haven't put enough miles on it yet to notice if it is low.
