What would cause the tail, brake, turn and reverse lights to all fail on only one side? Anyone venture a guess? It happened suddenly and putting new bulbs in did not fix. I don't think it is a fuse as they work both sides. Usually when the turn bulb goes, the blinker will only light that side, not flash, which is happening now. All of this is only on the passenger side, rear. The front turn light comes on. Brake light and all other lights work on drivers side. Could this be a ground issue? I have not had the time to pull the assembly to see about the ground. I will try that tonight after work.
I have a 72 pig, stock as far as electrical goes. The exception being the dome light that never worked so I DC'd it recently and put in a battery operated one, isolated from the rest of the rig. this problem happened a few days after that.
Thanks in advance for your thoughts.
