tailgate insert '78
JPB
Raleigh, NC
I'm looking for a tailgate insert that would bolt up to the stock hinges on the amby doors.
help please
Both SOR and CCOT make these. The ones that mount to the factory Ambi door hinges are the ones with 'ears'. Others make/sell them as well. I assume you mean you need a tailgate for use with a soft-top??
Check here for one example - scroll down the page for the tailgates.
http://store.yahoo.com/coolfj40/sparetirecover.html
AndrewT
yes a tailgate to use with the softtop.... I looked all over SOR and only found the half doors and the diamond plate tailgate that you have to drill new holes for.
thanks for the link
I made mine out of 1/2" marine plywood. It bolts to the ambulance door hinges. I screwed a peice of c-channel aluminum across the top edge to protect it when lifting stuff in and out of the back. I painted it with oil based rustoleum to match the rest of the cruiser. You can't tell that it is wood unless you are touching it. It has held up great for more than fifteen years, doesn't rattle like some of the steel panels and it only cost about $15 dollars.
Chase77 said:
check out the gozzard composites repro. think its about 90 bucks.
I'd love to check these out. Any clue where you get them from or have any pix to share?
AndrewT
