Tail & Rear Running Lights FJ60 Not Working
I know this is a very old thread, but did this ever get solved? I'm running into the same issue. No taillights, but brakes, signals and backup all work. 87 FJ60
I have a 1987 FJ60 and the Tail and Rear Running Lights suddenly stopped working. We have chased ALL the obvious suspects--fuses, grounds, bulbs, the light switch tested good, wiring, fixed misc loose connections and wires. STILL does not work. We are also getting a max of 4.8 volts at the tail light socket and 12 volts at the brake light. We've run out of ideas...any suggestions?
I had the same problem it took alot of testing but I found my issue, the ground at the licence plate lights was rusted and shorting out. many hours to diagnos minuites to fix.
My issue was a little bit worse... The connector plug had corroded complete, and a few of the wires were broken, as well as a rats nest of wiring for a trailer harness. I had to rebuild my entire rear harness. I bought factory color coded wires from Coolerman and rebuilt it all. Looks brand new and everything works properly now.
2032463
2032464
View attachment 2032463View attachment 2032464
OUCH at least it's fixed now
