Hi all,
Since the purchase of my 80, some months ago (HDJ80 12s 1991), the tachometer doesn't work.
The former owner had tinked the tachometer wiring with an electrical domino and other to add a "circuit breaker" on the injection pump, he told me he had stopped working after an engine drain.
The tinkering on the wiring is located at the level of the oil filter, this explains the beginning of this issue...
Moreover, in the Toy manual, I think about two root causes:
-> Either he reversed the connections and the diodes are burnt (can we change them?)
-> Or the sensor doesn't work properly (ref 83180-60070). Indeed, its resistance is 838ohms against 730ohms recommended by Toyota
Can anyone enlighten me on this point? Thank you
