Tachometer not Working
Fzj80 1997
Hi guys, the tachometer stopped working on my truck and I was wondering if anyone else has run into this issue. All other gauges function properly, the tachometer is stuck at zero and doesn't move at all. Any help on the matter is very much appreciated.
Well, it's always helpful if you post what year the truck is! Since there are at least 3 different versions!
Could be a number of things from the ground wire, to the distributor signal if its a later model. or Simply (and most likely) the tachometer itself is burned out. you can search for an electrical gremlin, or you can try and find someone on here that can sell you just the tach or a whole gauge cluster and see if that solves your problem. Check the part out section or message @Deathvalleypaul to see if anyone has one laying around. You can swap the tachometer into your existing cluster so you dont lose your accurate odometer and what not. I absolutely hate chasing electrical gremlins so I take the lazy route first and swap the actual part thats not working.
A few threads on here have shown that this was resolved by replacing the actual tach unit.
Thanks for the tip. I’ll look into finding a replacement
