Tachometer jumped to zero
Cincinnati, OH
This morning i started my LC, put it in drive, and all of a sudden my tachometer jumps to zero, my ABS light comes on, and my radio goes silent. This all happened for just a second and everything went right back to normal after that split second. Any ideas?
IMHO, electrical gremlin like that=check starter contacts.
Do your power windows work?
If not, I had a similar problem. Turned out it was only a fuse in the drivers side kick panel. Can't remember which one but check there first.
When the gauge fuse (center row, center position on the DS fuse panel) blows the Instruments, windows, moon roof become inoperable. But this is not your problem if the situation corrected on its own.
My '94 Toyota pickup does that wild tachometer bounce sometimes. It'll show 1000 rpm, then jump to 2000 or drop to zero momentarily. It is weird and intermittent. Maybe related to humidity.
i had a similar experience last week. It was as if the engine lost electrical power, studdering/hesitating when it dropped in rpm. You might explore the wiring harness. I had a short in the TPS bundle, i suspect from the extension that was added. i respliced all the connections and im still a little suspicious but it hasnt happened since.
try wiggling wires w/ engine running trying to duplicate your symptoms.
what is the TPS bundle, and where is it located?
