Tachometer from diesel cruiser
Saratoga Springs, UT
I need a tach for my 2UZ conversion, but unless I buy multiple inductive tach adapters, I only get one pulse per cycle.
I was thinking that since the diesel use a completely different tach system, that I might be able to use a diesel cruiser tach instead.
First off, does anybody know how the tach works on these?
Second, is this going to be a hard item to find?
Im not familiar with the 80 dashes but im wondering if parts of the tach from a FZJ100 with the 4.7 would somehow retro into the 80 housing.
It appears the problems with these products are exactly like you said, you'll only get 1/8th of the signal you need to drive the tach.
http://www.sunpro.com/product_detail.php?pid=16469 or http://www.msdignition.com/Products/Accessories/Tach_Adapters/8918_-_Tach_Signal_GMR_Pickup.aspx
This one looks like it may be a signal multiplier but need to read more
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=99 and http://www.autometer.com/productPDF/0561B.pdf
Im not sure how you would generate a square wave signal so the tach will see 4ppr in any other way ?
Suprizing that we dont run into this problem with the aristo swap ge = dizzy vs gte = cop
Nor did I have this trouble when I did a 5vz swap in place of a 3vz
2003-newer went to a different type of signal. No longer a signal from the igniter, with the described "pull-up" conditioner. If that was the case, the stock tach would still work, just be low. In fact the voltage coming off the tach wire is a constant 5v if I remember right.
As for the 2JZ and 2JZGTE still work, and 3vze/5vze, they still use a pull-up conditioner tach. Another issue is that the 5vze and the wasted spark. The 2UZ is not. That is my issue. I only get 1 pulse every cycle instead of 2 from a wasted spark system. Even that would not be enough, and would probably need to purchase 4 inductive tach adapters for an after market tach to work in 4cl mode.
The tach in the Diesel FJ80's might be different depending on how the signal is generated.
