Tach set up?
So my buddy has a old tach that came on his truck but it's not hooked up...how do these things usually hook up?....its got a couple of different connections,
Ground
Bat
ign
light
I think thats right...I'll get a pic of it tomorrow to be sure
Thank in advance!
Typical schematic albeit your colors may be different. Must be sure the pulse wire (the signal wire going to the coil) is the correct wire.
you proberly know this already but the taco should come from a same # of cylinder truck if you're running off the coil, that or the taco should have a switch (usually only on after market ones)
it would be pretty tricky to run it on a diesel engine but with no coil
what kind of ignition. If you have the coil on top of the dizzy, you will have two wires coming out of the tab of the coil. There is also a center wire there that you need to hook the tach to.
Most aftermarket tachs have a switch, on the back or inside to select the # of cylinders
