T100 idling problems
Virginia Beach, VA
Howdy,
My 3.4L in the T100 is having some problems idling. It was working fine until I cleaned the throttle body, and now it idles way too high, and varies between 1800 and 2500, with no throttle.
I triple checked the throttle body to ensure that the throttle plate is closing completely, and that there was nothing stuck in there holding it open. I also triple checked my vacuum hoses to make sure that they are all hooked up, and even ran a vac test and the vac system checks out fine.
Pertinent info: 95 T100, 158k, I also changed the oil and did a coolant flush at the same time as cleaning the throttle body.
So, What did I screw up?
Thanks,
Dan
