T100 ADD 4wd problems
SE South Dakota
I have a 95 t100 and just noticed that 4wd will not engage(worked fine last sping). I located the vacuum lines on the acuator and firewall and they same to be intact with no cracks.
Here is the strange thing, while trouble shooting I reversed the lines on the acuator and then 4wd engaged as soon as I shifted into 4wd?
My first thought was a bad line so I switched them back to std on the actuator and reversed them at the electric switches, same thing instant on?
anyone have diagram for the system?
I am not exactly sure what your problem is from your description, but I hope these will help.
:cheers:
Dan
I would check for you, but I took the ADD out of my rig....
I'll take a look through the manual tho...
Try the tests above. They should be able to isolate the problem.
That should be the same solenoid as on a mid 90s pickup, or maybe even a taco. I'd send you one of mine, but my pickup is on vacation in CA.....
See if you can pull it off and take it to a junkyard to compare.
