1HD-FTE, 2006, anyone with first hand experience please advise.
My version of Techstream shows t.p.s. as % instead of voltage, so I researched and found that some say that it should be 0% at idle and 100% at w.o.t.
Other results say, "
My original readings were 17% and 70%, and rotating the housing fully clockwise gives me 12% and 70%, within spec at idle, but not at w.o.t. which hasn't changed at all.
- Idle: Usually 0% to 15% (varies by model, sometimes idling around 10-15% is normal depending on how the ECU interprets the closed throttle voltage).
- WOT: Typically near 100%, though some systems may read slightly lower (e.g., 80-90%+). "
