I am just finishing up a t-case rebuild, and I am setting the pre-load on the rear output shaft bearing. I noticed that I cannot get within the spec of the FSM. With no shim I am under the specs(8 inch pounds) and with the smallest shim I am over specs(28 inch pounds). Specs is (13 - 21.4 with new bearing) and (6.1 - 10.4 with used bearing). I have a new bearing. Would it be better to be a little over or a little under? I was thinking over since it is a new bearing, but I thought I would see what others thought.
Thanks
Thanks
