t-case shifter ?
Trying to figure out how this goes together. I had the vacuum butt with my lt1 4l60e i thought i stick the manual parts in there. I think i figured it out...but the connecting rod that goes the the 4wd actuator has got me a little puzzled. the rod slips in to the goove on the shaft and has a notch for it to fit but what holds it there? I don't have any hardware either. any ideas?
In a stock application, the lever is on a pivot, and there is a nut on the end of the pivot that prevents the lever from moving laterally on the pivot, and only allows it to rock for and aft, actuating the front drive coupler onto and off of the front output shaft in the nose cone, when connected.
Good luck!
-Steve
