Synthetic rope
Nashvegas
Those that are running syn. rope on their 8274s, how did you attach the rope to the drum? Do I need to put a grommet in the hole in the drum or grind the opening smooth so that it doesn't cut into the rope?
you will never ever ever pull from the attachment point only.....the friction of the rope against the drum and the first 8-10 wraps is where the resistance is from....you can also get "sneaky" and crosswrap the first few, so it's effectively clamping itself to the drum.
I just tied a knot in mine and spooled it on...been like that for...mmm....2.5 years? - no problems.
Thanks Woody, that's what I needed to know. How many feet of rope did you put on yours?
originally, 150 of 5/16"...cut off 30' tho for a spotter rope, and then lost about 10' to a break last year
it really does "fall" when it snaps....
IMO, 100-120' is about perfect, I'm too lazy to check it on side pulls and the shorter length keeps it from overloading one side too much ;)
