B -
>> I also noticed that my SWR changes with different frequencies... Is this normal or whacky?
Normal. SWR is a function of frequency: Change the frequency, the SWR changes with it, sometimes imperceptibly, others times quite significantly. Depends upon the circumstances.
SWR measures the ratio of forward power
vs reflected power, so as the SWR changes, so does the forward power measured on a watt meter.
Larry's advice is good, but Bird meters are top-of-the-line precision instruments (very $$$). Not everyone has one sitting on the shelf to tune antennas.
In any case, these type of measurements are not a "do it once and you're good to go" affair. There are countless factors that can change antenna tuning, so it is something you need to check periodically just like any other PM on your truck.
Best advice is to loose the marine meter and get a quality power/SWR meter that is designed for the frequencies you will be using. It will be a valued investment that you will use frequently.
This "I just found this cool SWR meter on
eBay for $10" stuff is nuts. Spend some time on the radio shop sites on the Internet, read the reviews, and generally do the homework. A proper meter alone will not help you. You need to understand what you are measuring. It will be time very well spent.
Cheers, R -
