Switching springs.... need alignment???
Fayetteville, AR
Long story short I had a shop install my ome lift. Didn't really have the time to do it. Told them multiple times the springs labeled "B" go on the driver's side and ones labeled "A" go on passenger. Get my rig home today and notice driver's side is sitting about an inch lower. I look under and the tags are still on the springs. The jackwagons put "A" on driver's side. Alignment has already been done. I'm taking it back to be corrected. Will it need another alignment if they're just switch out the springs?
I'm with ^^^. About the only alignment they did was toe in and steering wheel placement correction.
I would be more concerned about what is being done for caster correction.
The only possible adjustment in an alignment is setting toe-in unless special trunion bearings are used. Toe-in will not change with spring height. What is important to determine the caster and camber readings. Did you have caster correction bushings, plates or drop brackets to address caster?
I used drop brackets.
