Switches, identifying
EVERGREEN, CO, USA
Does anyone know how to identify what switch was used in what year FJ40?
For example; lets say u find a hazard switch in the junk yard with "TOYOTA SAE-QC70 22-3" stamped on the case. Also a PAT NO. on the case. Now, what year(s) FJ40 was that switch used in?
What I'm doing is disassembling the switch, cleaning and doing a reverse engineering job of figuring out how it actually works. Then making a diagram and pics of same to post for record for the FJ40 forum. The one I'm working on now has a 9 pin connector (all pins are wired) that plugs into the main harness and some of the wires are color coded the same color; but they are not really the same. Toyota uses the stripe as a coding guide; for example; GREEN/BLACK [G/B]. There are two G/B wires, one with a wide stripe and one with a narrow stripe.
What I would like to find is the engineering drawings of the switch from Toyota. Maybe Cdan has access to this info; I'm sure that this stuff is company private, but who knows.
dfm
