Sweet complete 2F in PA $675
Status
Not open for further replies.
NE PA coal region
Engine has been sold!!!!!!!!
2F engine in a 84 FJ60 sounds tremendous, no smoke or bad noises, has a recent OEM carb (cost the previous owner $985). Includes the power steering pump (no leaks), alternator, AC compressor, smog pump, air cleaner, and gear drive starter. Will throw in all the smog stuff if you want it. This engine is equipped with the good electronic distributor. I'll include the coil and ignitor with this engine. Fan and fan clutch and all belts in place. Will come with the complete clutch assembly and bellhousing. I need to get $675 for this engine, it would be a drop in turn the key install for you. Oil is clean as is the coolant. Still sitting in a running FJ60. Compression results: #1- 135, #2- 132, #3- 129, #4- 128, #5- 130, #6- 131. This was done dry, these are good results. Email me at home shmukter@pa.metrocast.net or call 570-668-2489 before 8PM eastern. Thanks, Gary S
I can't beleive knowone has bought this yet. Bump again for what looks like a nice 2F. Has all the goodies on it, electric dizzy, gear reduction starter, new carb.
Good luck,
Jeremy
Bump for Gary-An excelent seller. I've bought lots of parts from him, and if closer, I'd be tempted to grab this 2F.
I'm picking it up on Saturday due to the sad fact that I found two thrust washers in my oil pan earlier this wk. Gary seems like a real nice, upfront guy. I'll let everyone know how everything works out....
Status
