I have always wheeled with my sway bar(s) connected. I like how stable it feels, and the travel isn't really affected too much. BUT, after the last Rubicon run, my front sway bar had ripped through the mount on the frame.
So I started thinking of a sway-bar disconnect. My goal was something easy to use. The ones I'd made in the past ended up being so hard to connect or disconnect (read: hammer, pry-bar, vice grips)
NOTE: this is actually a HZJ79 with 80-series axles. The suspension is identical-ish to an 80... I'm putting this here because I think it will be more useful since there are thousands of 80-owners here and only a few 79-series (and they mostly don't wheel their 79s). Also note... trying the "imbed photos" thing... first time.
Anyway, I bought some "Steinjager" Heep disconnects
I bought them here:
J0030838 Steinjager Quick Disconnect Front Sway Bar End Links Jeep Wrangler TJ 1997-2006 2" Lift
They use a ball-socket disconnect which seemed like a nice design and easy to (dis)connect. (they are)
I then removed the stock frame mounts, and cut them with a band-saw.
I welded the "ball" to the cleaned frame mount.
I then cut the the stock sway-bar bushing mount clean, and welded the other end of the sway bar.
The final version: I had to rotate the Sway-Bar bushing mount 90 degrees as it was able to twist away from the mount. Final version here. Note: I also shortened the links.
Now I am able to disconnect or re-connect the sway bar without tools in about 15 seconds. When the sway bar is disconnected, it lays on the front axle trailing arms and I use a bungee cord.
I bought them here:
