Sway bar question
Reno
Last summer I had purchased a 2.5 OME lift kit med/heavy springs with heavy duty sway bars. They seem to be almost to stiff when going off road like I dont have enough flex. Do most of you use the stock bars or upgrade? Seems like I will have a tire hang in the air when dropping in to something some what steep and uneven like a ditch for example. Considering swithcing back to the stock bars to see if this helps also I only have an ARB non winch bull bar for accessories maybe the springs are too stiff? Any advice would be appreciated.
I've got a pretty sweet hybrid lift of 4-5". I don't have any sway bars on, and I get enough flex to drop out the rear springs without too much hassle. I am going to get some new drop brackets from Slee soon though. If you don't want to limit flex, do like some of the other guys on here and put on quick disconnects so you can get the benefits of sway bars on-road, and the benefits of no sway bars off-road. Just my $0.02
It's a little unlikely (though possible) that the springs are too stiff.
General, shocks and/or sway bar(s) are what limit's flex.
You can drop the old sway bars back in and see if that helps, or, even better (IMHO) is to find somewhere that you can take the vehicle that'll "twist" it up and then get under it and see (by disconnecting) what's limiting the flex.
You can also put it up on jack stands, drop out the springs, then hook the shocks and sway bars back up and see what's limiting it.
Fred
