I'm doing a bit of TLC on the suspension of my 97 and I have replaced a few sway bar bushings. On the front sway bar, at the back of the bar, there is a piece that looks like a tie rod end that attaches to the frame and has a flat part on the bottom that the D bushing connects to.
My question is how does that joint work? Should the joint be like a tie rod in that if it can be easily wiggled around it is bad?
When I disconnected the bottom part so it was only connected by the tie-rod joint end, it moved around very easily, wasn't stiff at all. I'm thinking these need to be replaced, but just wanted to check.
BTW - what the heck is that thing called, besides the sway-bar-support-tie-rod-end-looking-thingie?
Thanks!
Thanks!
