Nice! Did the same thing thanks to you.
What method did you use to flatten out the grease cap?View attachment 939618
Here is how she looks. And here is how the hammered flat cap looks like.
My shop (Discount Tire) told me the same thing! They all acted very confused when I asked if it wasn't a bad move...You can definitely leave the cap off...although you can obviously expect the grease inside will flow out of the hub and make a good mess...not to mention the bearings will then be starved for lubricant.
I would find another "shop". Immediately.![]()
Steve
I don't believe you can run without caps and not have grease flowing out of the end... They are very cheap to replace and easy to flatten. Did you think of getting an extra set from the dealer and playing with those?My shop (Discount Tire) told me the same thing! They all acted very confused when I asked if it wasn't a bad move...
Does anyone know of any flatter dust caps?? There has to be someone making some!
Hi, it was really easy. On one side I took out the cap and went at it with a small flathead hammer. I only needed a about 5 mm or so of space. On the other side I simply hit it with the hammer (Conan the Barbarian style) in place until it was where I needed it to... Very straightforward.What method did you use to flatten out the grease cap?
Looks great on the Lexus. I now have a 200 series and I am looking to get a set of 20's from the Sequoia which appear like they would look great on the cruiser.
As I’m sure you’ll find,there are many 100 series owners running spacers, some as wide (thick?) as 2”, with few issues. I guess it comes down to how much you are comfortable modifying what Toyota designed. There areno hard and fast data that I’ve seen that suggest mild wheel spacers create undue stresses.
@Andres G Ok so let me get this straight in my head.. So you bought new grease caps, basically put them on a bench and wailed on it with a hammer to knock it flat by about 5mm (from original cap height) then put it on. After that you worked on cap fitment by simply rounding out the edge and working on the inside of the hub cap? Can you show comparison of your "shortened" cap vs. stock?View attachment 939618
YES@Andres G Ok so let me get this straight in my head.. So you bought new grease caps, basically put them on a bench and wailed on it with a hammer to knock it flat by about 5mm (from original cap height) then put it on.
The cap went in place pretty much flat after I’d hammered on it. Minimal grinding done on the inside of the hubcap of the wheel.After that you worked on cap fitment by simply rounding out the edge and working on the inside of the hub cap?
unfortunately no. I have sold that truck (kinda miss it a bit to be honest... minimal issues, same crappy fuel consumption, a bit less comfort than my 200)Can you show comparison of your "shortened" cap vs. stock?
