Swapping turn signal switch ass'y?
38.0111,-109.9181
Website
www.alamosa.fm
The 100 series and other Toyota newer vehicles have the ``fog light'' switch on the turn signal switch assembly (I've actually asked this before but can't find it in search) which would be nice to use as a switch for off-road lights.
Is this assembly easily swapped out with a 100 series switch or even a 4Runner/Highlander switch with this extra fog light option?
You have a 100 series, an FZJ, and a 40-why don't you go find out on your own!! :flipoff2: :flipoff2: :flipoff2: :flipoff2: :flipoff2:
IM me.
the light arm/stalk is attached directly to a switch asembly including the wiper stalk on the other side. the light and wiper share a single large plug, they could be sperarted though. by depinning and taking apart the switch. I dont know about seperating the stalk from the switch. IIRC there is not a seperate plug for the light stalk
Thanks, the only thing I have found online was this $OR diagram:
Where it does appear it has a separate 3 pole plug, but I'm not familiar with the mounting on this and may have to do some playing tonight if I find some time.
that is not a 3 pole plug but just 3 wires with terminals/pins. the plug can be depinned though
If you figure this one out plese let us know.
here are some pictures (for sale by the way)
RavenTai said:
The plug can be depinned though
repinned or depends...er...depinned. You may need the previous after the time it will take you to get this done :flipoff2: :flipoff2: :flipoff2:
Seems like a possibility-and I would assume a very quick replace, assuming the lever matches to the 80 switch. However, I would guess you would need some detailed wiring description as the 100 switch has the "auto" setting for the headlights...did the 100 or 105 come w/o the "auto" somewhere, hmmmm. Mot?
Blatant hijack...
spacers will come down with me, so will j-dogs 80 that we just installed his rear springs on last night, my 80 will sit nicely in its home :D
