swapping in a 2f, replacing an F
Breckenridge, CO
I'm all set to pull out my siezed F engine tomorrow and replace it with a 1986 2F. And after getting it all prepped for that, I have a few questions.
I planning on keeping my current carb and putting that on the 2F. (throttle linkage issues) therefore...
I'm quite sure there is going to be all sorts of smog crap and hoses that go nowhere. So as long as I have the basic vacuum lines hooked up and the rest plugged I should be OK, right? I want to try and hook things up like they were on my F, its a 1971 without any smog equipment so I figure thats a good reference.
If that all works out, what about the AC pump and the power steering pump? Do they need to be hooked up with proper fluid?
The AC pump I don't have a clue about, is it just an air compressor? Does it need some sort of air filter?
Sorry for the laundry list of questions, but I have a few more and I'll throw them in another post.:cheers:
put a 2f in my 70 used the 70 manifold took off everything else and it bolted right in used 2f alt for more amps unles you have power steering and air you dont need that stuff
