Swaping O2 Sensors Injector Testing
North Front Range, CO
1 2 3 spark plugs are good.
4 5 6 are carbon covered or carbon fouled.
My performance is down but mpg is the same.
My thinkin is that I either have a bad O2 sensor or three bad injectors.
The later is a stretch as they are all three in the rear bank of injectors.
Is it true that each O2 controls each set of injectors?
Can I swap the O2 sensors to see if the rear plugs clean up and the front ones carbon foul?
The O2 have about 50,000 give or take on them.
Is it possible to test the injector without removing them?
landtoy80,
The O2 sensors in your truck don't work like that if you have one upstream from the cat and one downstream from the cat. The computer uses the the signals of the two O2 sensors in conjunction to adjust the fuel/air mix across all 6 cylinders--they don't split cylinders between the two sensors.
I can help clarify, but I'm not sure why the three latter cylinders are fouled!
My 80 has 2 O2's and 2 cats side by side.
Both O2 are before the cats, no O2's after the cats.
One O2 is on one header pipe before the cat and other is on the other header pipe before the cat.
Right--94. I see that now. oops! Then, yes, your logic of each O2 affecting each set of cylinders is correct. One header pipe handles three cylinders, right? My 95 has one O2 pre-cat and one O2 post-cat so the setup is different.
However, swapping them to check the performance of the possibly "bad" one would or could just result in the other three cylinders running rich. How old are the sensors? If they be old, might just be better in the long run to replace one or both of them.
Toyota O2 sensors or aftermarket? Mileage on the sensors? Did you check for diagnostic codes using your in-dash CEL mod? :D Just kidding. But did you see if you have an O2 sensor-related code?
If it were me, I would probably lean towards the culprit being the O2 sensor since the sensor response degrades over time, but I can understand wanting to avoid parts swapping as a method of fixing things. Better to diagnose as much as possible.
And in board terms, I'm a complete newb compared to you (almost 4,000 posts? wow!)
Dang. Any codes at all?
I would check for a wiring problem on O2 #2 (DS/left). that is what was wrong with mine. My signal wire had been cut and rewired by PO incorrectly.
I have code 25 26. Rich and lean.
My O2 wires were pinched off 4+yrs ago. I spliced them back in with dielectric grease. I used shielded wires and had no problem up until lately.
Guess I need to check the wires with tester.
Where is a good place to unplug the wires to test?
Do the wires from the O2 to computer have a plug or does it go straight into the computer?
I see now. This is why you want to see which code comes back first after clearing them. Can't help you on the wiring details of a 94.
The wires from the O2 go into the wiring harness then go into the ECM. I could not decipher the wiring diagrams to figure out which wires on which plugs at the ECM were the O2 wires. I ended up testing the signal wires at the diagnostic block in the engine compartment because those are clearly marked. In my case, the PO had wired the shield into the signal wire. The shield is grounded so that causes problems. hehe.
