Swap H2A for H2AV, Tips?
Moncton, NB
Hello All,
Did some resaearch and I think I got it, but please give me your insight.
I'm looking to buy a JDM HDJ-81 with a transfer case (H2A) noise. I'm planning on swapping the t-case with a local 1997 FZJ80 (H2AV) unit.
I've read that the drive shafts are different sizes. Can someone confirm this? Also, I'm assuming that it will mount to the truck in the same spot.
Any tips / advise would be helpful.
Thanks
YES. Shorter drive shaft for the HF2AV as Viscous coupling adds about 4" to the length of the rear output casting. Longer case = Shorter prop shaft.
HF2AV off a 97 will have come off the back of an A343F tranny, not A442F like you have. Might be a difference there too. I would try to avoid using a Viscous coupling case if you can. I personally don't like the resistance it seems to feed through the drivetrain and the implications for added wear in birfs etc. Especially on the earlier models with shorter Birf splines/ drive plates.
If you can get an HF2A off a US FJ80 you would be in better shape for bolt in compatibility and no shaft mods.
