Swampbox Cargo Drawer
Okefenokee, GA
After checking out all of the cargo box systems in the FAQ thread, I figured that I would build my own as I really have a need for it. My plans were to make it extremely beefy with about a foot of depth in the drawers. I also have plans to make it completely flat from one side of the vehicle to the other to make it look more natural.
These first two pics are shots of the lumber I purchased to make it. I purchased 2 4'x8' sheets of 1/2" plywood and 2 2'x12' pieces of yellow pine in 8 ft sections.
I know the 2x12s are a little overkill, but they were too sexy to pass up at the lumber yard. All in all $42 for Lumber and $2.50 for Wood Glue and $5 for some 2" deck screws.
The next step was to start putting the actual box together. As my table saw has stopped working I was forced to make all my cuts with a skill saw. Not perfectly straight, but good enough that I can sand and plane until it is too hard to notice.
My top and bottom piece of plywood are cut in 39" X 43.75" rectangles and my 2x12s are cut at 39" lengths. I sealed the back of the box with 2x12s as well and they were 18.5" long.
The drawer slides that I used were from Lee Valley & Veritas and were 36" and rated at 250 lbs. I ordered them several months ago, but I believe they were around $85 including shipping.
The next three photos are pictures of the drawer slides mounted in the mouth of the box.
It has taken me about 4.5 hours to get to the stage I am at now. The constant measuring and remeasuring has added to that timetable, but it is worth it because the core of the drawer system is square. So far I have used a ton of wood glue as well as 44 screws and am happy with the progress so far.
By this weekend I hope to have the box carpeted and installed in my truck, have the drawers put together, carpeted and installed and have my flanges fabricated, carpeted and installed. The hinges I have purchased cost $25 at lowes and the recessed cargo latches cost $75 from SouthCo.
More updates tomorrow and this weekend.
looking good, i still cant convince my wife to ditch the third row seats, once she gets a different rig i told her im doing whatever i want to MY cruiser! :D
Romer, feel free to link this into the FAQ thread after I'm finished with the project.
I'll make sure he gets right on that.:flipoff2:
How long have you been married?
Do you have the number of a good attorney?
I told my wife the same thing....After I picked my teeth up off the floor, I told her it was going to be practical, functional, etc....She was cool with it then.
sj
1-800-dentist should help with the teeth problem. A reputable practicioner should be able to replace your lost ivory and help with any over/under bite situations which you might be having.
COOL is a very relative term.
lol...It did come out a bit pushy, huh?
Today I decided that I would go ahead and get the box carpeted so I went to lowes and bought a 6x10 section of grey industrial carpet. I tacked it on using an air compressor w/ a brad nailer and some adhesive spray.
The adhesive spray wasn't as tacky as I wanted it, but it did help me get the carpet flat and pretty much straight.
This is what the box looked like after carpeting it and putting it in the rear of the truck. I finished the back of the box, but am still working on the front.
To help keep the carpet in place I am using 1/16" aluminum with a 1/2" on one side of the angle and 3/4" on the other side. Turns out that the 3/4" side fit perfectly over the carpet and the 1/2" plywood.
The second and third pics are what I am using to build my drawers. One is of the L shaped flange which I will put in the top corners of the drawers and the the T shaped will be placed in the bottom corners.
For the carpet, drawer braces, contact cement and aluminum, the bill came out to $80. So far the total cost has been a little over $300--which is about what I had figured.
How did you secure the box to the truck?
It weighs about 150 lbs, it's wedged in between the wheel wells and there is a 70 lb. wheel/tire on top of it. I was going to bolt it down, but my friend helping me as well as myself could not pull it out after we got it put in.
I am still going to bolt it down, but instead of using the bolts from the 3rd row seats, I am going to use the holes from the 3rd row seatbelts, and just fabricate a 1/4" piece of steel to connect/secure it.
Sweet. Just curious. I had my box attached to the 3rd seat brackets... after about 5 mo, one good jump ripped it appart. :doh:
the box or the bracket? if the latter, what bracket was that?
:cheers:
good work
:D
