Suspension - Ride, Weight, Limits
New York & California
Website
www.rbfilms.com
I am starting a new thread for this question that came up in the Auxiliary Fuel Tank thread I started.
I have a Lexus LX-450 will be my daily driver which is being built for Off Road use.
I will be running Full Lockers, 4.88 gears, ARB Front Bumper, Hydraulic Winch, Dual Battery, Supercharger, IPOR Skid Plate, Slee Sliders, Slee Rear Bumper & Tire Carrier, AFO Roof Rack, IPF / HID Lighting, CB / Ham Radio Electronics & Amps, and of course this 46.8 gallon Auxiliary Tank.
I have now stopped short of adding rear drawers and a refrigerator ... which I would like ... due to concerns about the weight of the vehicle and the resulting load issues and ride quality.
Here are the details related to the question I have.
I will have a total fuel capacity of 23.2 for the Primary Tank and 46.8 Auxiliary Tank for a total of 70 gallons (420lbs).
On average, as my daily driver, I will run about 50% fuel capacity or 35 gallons (210lbs).
When traveling I will have full fuel on-board (420lbs) plus all of the permanently installed gear listed above in addition to 500 to 600 lbs of luggage and passengers.
A few guys from OZ said that these heavy springs may “rattle the teeth out my head” without full fuel and gear on board. What do you think?
Will the Slee Heavy Rear Springs be too heavy for my Daily Driver use without full fuel, gear, and only the driver on board?
Would the Slee Mediums in the rear handle the full travel weight with full fuel, luggage, gear and passengers? If not, someone did mention adding air bags for those travel days to supplement the rear springs.
I am looking for a good ride with and without gear. What will give me the best overall result?
Any experienced opinions would be greatly appreciated.
Sorry, I shoudl have mentioned that.
4" Slee Medium Front with ARB Shocks
4" Slee Rear with ARB Shocks
Film -
Are you talking the OME 2.5 lift or are you talking more like 4" or 6" springs???
Cheers.
- Mark
Without a heavy load that is going to be very stiff. I suppose it will depend on how much you carry with you on a daily basis.
I would suggest giving Christo a call. I think he'll be able to match you up with something that'll fit your needs very well, and he'll be able to ask some specific questions (though you've given us tons of info here).
As a slight comparison, I'm running the OME 2.5 heavies w/OME shocks front and rear. No aux tank, but ARB and M12000 with dual bat up front and Kaymar w/tire carrier, ARB fridge, full tool drawer and CO2 tank in the rear, Hanna sliders and Slee Tcase protection. INTI rack w/full set of PIAA's all around and that rack is loaded to the gills on most scout outings I attend. I also have Airlift airbags in the rear springs usually around 20 lbs which does stiffen things a little more IMHO. Running 285 Revos too if that helps also. When I'm out by myself wheeling, I remove the 2nd row seats an install a second storage drawer extension to the rear drawer.
I don't think the ride is bone jarring at all. You'll love having the fridge an drawer back there. I wouldn't hesitate to put an Aux tank back there if I had the $$.
F.O.R. is about to release a fully progressive 3" spring with custom shocks that is designed to keep you in the progressive rates over about 350 lbs of load variance in the rear. This would be worthless if you have so much weight that you are never using the progressive feature, but it might be worth a phone call to see if that system would meet your needs.
I think pretty clearly that you will be a perfect candidate for a progressive rate suspension rather than trying to balance the high spring rate required for load carrying with the undesirable effects of that spring rate when not fully loaded. Just depends how heavy you are really going to make this thing. I don't think the aux tank alone breaks the bank if you are careful with the other stuff.
[Slight hijack:] Can you and Landtank document any special concerns and considerations when installing and plumbing the hydraulic winch? I like the idea of hydraulic, but I don't know enough about it at this point to design a system and install it properly. Thanks!
[/End of hijack]
What do you guys think of running medium duty springs and air shocks(shock absorbers, not the things that attempt to replace coilovers). This will allow you to add pressure to the shocks to compensate for the heavier loads when you're traveling.
Just an idea.
Just an idea.
Do you mean airbags?
That's probably a good way to go, though airbags will reduce articulation when wheeling (if they are inflated at all).
Adjustable ride height air shocks (assuming you actually mean them, such as what's on stock on the LX470) are pretty expensive and generally not worth it.
That is a tall order Rich and any opinions you get are going to be subjective as "too firm" for one person is "not firm enough" for another.
My recommendation is build the truck like you want it; fridge, drawers, aux tank, and any other things you want in the cargo area.
The 4" height is a good choice for moderate to heavy wheeling and 35" tyres. You have a few choices for springs and suspension at this height. Slee medium, Slee heavy, Nay's new FOR springs ( ? ? ?), maybe the Comp OME springs, and then air bags.
Once the truck is at operating weight, drive it with the Slee heavies. If that doesn't suit you then swapping springs or adding the air bags is trivial and inexpensive relative to all your other mods. You could try the other options if you are not happy with the 4" heavy springs. The important thing is to equip the truck like you want it and then tune the suspension.
-B-
Hey I'm just suggesting giving F.O.R. a call after talking to Frankie a couple days ago. You can call them mine if I get to run a pre-production set again :steer:. I have literally had nothing to do with the development of this new suspension.
I do run airbags for towing, but they work just the same for extra weight you'd be putting in there. I don't wheel hard enough to worry about extreme articulation...at least nothing I've done where I've noticed a problem. :D Airbags will run you less than $100 installed yourself. A drop in the bucket compared to what you'll be spending on the entire lift.
No, I mean airshocks. They are standard looking shock absorbers with schraeder valves that you inflate with an air hose. I put a set on my dad's old Yukon for ~$70.
That would only affect the damping (compression/rebound), not the load carrying capability, would it not? The load is carried by the coil springs, the shock only controls how fast/slow the axle can cycle up and down over bumps/dips
Incorrect, these partiuclar shocks transfer some of the load to the shock mounting points.
Arya is correct, air shocks do carry some of the load.
I remember reading that a lot of people were not particularly impressed with the LX470's air shock system. Virtually everyone who had them replaced them with standard shocks once they went out. I do believe it was about a 2" ride height difference that they made.
Personally I wouldn't want to put a ton of weight on the shock mounts. While they are extremely beefy compared to many, if you're putting a huge amount of weight into the 80 (already a heavy rig itself), that's a crap-ton of weight on those mounts, and they were not designed with that much weight in mind.
The spring perches on the other hand ARE designed with that much weight in mind.
Airbags are a very cheap and easy route to go, as well as being a very sturdy setup. The only way they are going to fail is by getting pinched in the springs (which fully compressing the springs anyway is bad) or by getting torn (and if you have something that sharp and pokey in that area, I'd be worrying about other things, like brake lines).
A shock has a much greater chance of failure (more complex, especially once you move into an air shock).
Additionally the 80's don't have the typical shock setup, so it's likely that you'll be using adapters to mount your air shocks or welding in new mounts. Welding in new mounts would have the advantage of allowing you to make them very beefy.... (I would not use an air shock with an adapter.)
Air shocks are very cool, but I personally would prefer the simplicity and design of the airbags.
The air shocks Arya is talking about is nothing like the system on the LC470.
I do agree with that. Also airshocks are very susceptible to temperature changes an they will fade on a heavy loaded 80.
Beowulf has he correct summation. Build the truck you want, then dial in the suspension. Our 4" heavy springs are a pretty good starting point for the weights you are looking at.
I think LandTank has a specific thread on this install. You can PM him to ask, but I am pretty sure he documented this already.
[/End of hijack]
I have this is exact issue and am trying to decide how to handle it. My truck is built very nearly the same way as Filmpros. Only difference is I carry a Maggiolina on top (about 150lbs) and have an OEM subtank underneath and then 2 jerry cans and a propane tank on one bumper swingout.
I have the OME 421 competition springs in the back and the ride quality is excellent. However, when I'm fully gassed up and the Norcold 60 is full, 23 gallons of water, plus climbing gear or whatever, my rear sags by about 1.5". So, Filmpros, this may at least give you a point of comparison for what it would be like running comp springs.
I had never considered airbags, but it seems like a great idea - especially if it really only costs $100 - that's cheaper than buying new rear springs. Is there anyone out there who has tried the airbags to address the weight issue and can give us some feedback?
The Miller boys have a lot of experience with the air bags. IdahoDoug's primary use is to level his truck when he hooks up the boat. He might not be following this thread so PM him with a link and maybe he will comment. In general, he is a big fan of the air bags in the rear springs.
-B-
