Suspension replacement - "while I'm at it . . ."
NY
I've ordered the following parts for my 256k mile LX, is there anything else maintenance wise I should replace while I'm at it? Tie rod ends?
TJM XGS Caster Correction Kit
OME SD24 Steering Damper
OME 2860 Coil Spring Front
OME 2851 Coil Spring Rear
Fox 2.0 Performance Series Shock Front 985-24-070
Fox 2.0 Performance Series Shock Rear 985-24-073
I just did the same thing and went ahead and replaced both the drag link and tie rod with heavy duty Budbuilt units, and replaced the TREs and DLEs with OEM units. Truck drives straight and the steering feels tight - I could not be happier with the results (and should last me many years)
I've been thinking about these FOX shocks with Dobinsons springs. Any chance you could post up link to where you grabbed the FOX shocks, and pricing if you don't mind?
Sure, here you go:
TJM XGS Caster Correction Kit $50.31 http://www.andysautosport.com/products/tjm_equipped__66310R.html
OME SD24 Steering Damper $91.88 http://www.amazon.com/gp/product/B004P9ONF0?tag=ihco-20
OME 2860 Coil Spring Front $167.20 http://www.amazon.com/gp/product/B004P9LRQI?tag=ihco-20
OME 2851 Coil Spring Rear $167.20 http://www.amazon.com/gp/product/B004P9IBVC?tag=ihco-20
Fox 2.0 Performance Series Shock Front 985-24-070 $230 http://www.ebay.com/itm/Fox-Perform...cruiser-80-Series-1-2-5-/391133249277?vxp=mtr
Fox 2.0 Performance Series Shock Rear 985-24-073 $230 http://www.ebay.com/itm/Fox-Perform...uiser-80-Series-1-5-2-5-/391133249582?vxp=mtr
Any reason to go with Budbuilt over Front Range? http://frontrangeoffroadfab.com/steering-links/
