Suspension Question
Longview, Texas
I recently purchased a 1997 FJZ80 w/ 200k and found that it has yellow shocks. I will be changing the brakes tomorrow, so I'll clean them off and see if they have any markings on them then.
Does anybody know what color the OEM shocks are?
I noticed that the OME kits come with yellow shocks. It's probably just wishful thinking, but I'd like to know if the springs from the stock OME replacements have any specific markings on them, so I know what I'm dealing with. These shocks may be original, but don't feel like they have 200k on them. They could also be Midas' specials with stock springs-- I'd just like to figure it out.
OEM shocks are black. OME springs come with a little tag on them that's says the model number and either A or B for which side of the truck they go on. Though the tags may have been taken off by the PO.
The OEM shocks are black. My Old Man Emu stock height replacment shocks have "Old Man Emu" stamped into the steel body as well as an OME sticker. I can also see "Made in" stamped in the steel but the shock orientation doesn't allow me to read the rest. I am pretty sure it will say Australia.
Lots of aftermarket shocks are yellow, you may get lucky and they'll be Old Man Emu or Bilsteins.
Nope, I got curious and checked.
The springs don't have any markings on them, I'm betting for OEM. They're black.
The shocks are these: Monroe Gas Magnum Truck Shocks - Shockwarehouse.com
Looks like I'll be getting the OME kit afterall. For now, I'm going to leave it as it is and grab some General Grabber AT2's in 285/75/16 and put them on there. From what I've read, they should fit without issue?
Would the OEM shocks improve the ride/ handling significantly enough to warrant purchasing and installing?
OME suspension will significantly improve handling and recovery. Firm road feel and stiffer on corners - less roll and flatter.
