Suspension question
Salt Lake City, UT
Hey all, I'm still baselining my 2004 LX470 w/ 150k miles when I bought it 1.5 years ago. I've put 5k on it.
Now I'm trying to figure out the suspension before I put bumpers/skid plates (yes, should have looked into this before).
Question: Do I need a Slee Diff drop and aftermarket UCAs?
The rig came with AHC deleted and:
OME 60000 Front Nitrocharger Sport Shocks
OME 2860 Rear OME Coil Springs
OME 60002 Rear Nitrocharger Sport Shocks
I think it's a 2.5" lift but without knowing what would be considered the AHC baseline I'm not sure. It's sitting on 285/75/16's and the front is 36" from ground to fender / 20.5" from center of hub to fender, while the rear is 38" / 22.5".
It has OEM diff cross member and OEM front upper control arms (UCAs). The front driver's side tire was worn on the outside when I bought it but a reputable shop in SLC UT said it was just the wheel bearings (they were definitely shot). They didn't say anything about the UCAs during the pre-purchase inspection. I replaced those bearings and got an alignment but now I'm worried I need UCAs that might have played into the abnormal wear.
After I do this work I will likely add Dissent front / rear bumpers and skid plates, then see if I need to upgrade shock/springs after adjusting torsion bars etc.
Thanks for your advice!
Is it because the front end is not too far from factory? What is the cut off in hub to fender before I would need to make these modifications? Thanks again!
The suspension components you have installed do not provide any more suspension travel than the factory settings. In fact, with those OME shocks, you actually have slightly less suspension travel than what’s provided by the stock OEM Tokico shocks. Thus, you’re well within the factory travel and geometry.
