Hi everyone, I have a 97 LX 450 with about 148,000 miles on it and am concerned about the handling. I just had some Rancho 9000 shocks put on and the handling is even worse. At highway speeds it wallows all over the place to the point its dangerous. I have the adjustable shocks set on the firmest setting. Do I need new springs or are these the correct shocks? Bushings in the suspension look good. Thanks
The OEM shocks on the 97 LX450 are too soft and created swaying at highway speed & turn when I first bought the truck and the swaying gradually disappeared. Eventhough it's still manageable for some 150k miles, I recently changed them to KYB monomax shocks which are much stiffer & the swaying is completely gone.
I had the same problem with mine swaying when traveling down the interstate or long, straight roads. After reading several threads at the time (about 7 years ago), it was suggested that I needed new springs. I bought the Old Man Emu Stock Height Replacement Kit from sleeoffroad and it completely cleared it up and made the overall handling and cornering much better and met expectations, plus some. I was very pleased with the results.
Lexus used softer springs (than the Landcruiser) when produced for that year, which is one of the few differences.
Replace your springs and it will get rid of the 'swaying' from the soft springs. I recommend the kit with the shocks & steering damper as well. There are optional kits for medium or heavy spring loads (like aftermarket bumpers, winches, etc). I installed myself and took half of the day, but was in no hurry. Some recommend someone to help when placing the springs, but I did it alone without any help. Instructions come with it. If you get the Old Man Emu, you must be careful when installing since they're from Australia and the PS (pass. side) & DS (driver side) is reversed.
Had same issue. Before i went OME 2.5 w/ nitrocharger sports, It made a huge difference to go to truck rated (D load rated I believe), tires from the stock tires. If I had not already purchased the 2.5 kit, I probably would have ran stock setup with the new tires for a while. Also depends what you want to do with it. Mine is a DD, not any wheeling to speak of, so ride was more important. Recently went to OEM Toyota shocks as the sports were just too rough for what my family uses it for.
