Got the LC100 front suspension dialed in
Upgraded with Dobinson upper control arms and OEM lower control arms.
Installed parts:
• Dobinsons C59-185 springs (2” lift, up to 440 lbs)
• Firestone 4164 airbags
• Delta VS panhard drop bracket
• Dobinsons diff drop
• Dobinsons upper control arms
• OEM lower control arms (L/R)
• OEM front lower control arm rear bushings
Huge shoutout to Jin @rootautoworks for the solid install and spot-on alignment — quality work all around.
Another shoutout to Vinh @firstimpressionautodetail for absolutely nailing the tint. The man knows his craft and worked with me to get it as close to OEM as possible using 70% ceramic.
Rear:
Spent 10 hours with a Bay Area legend working on my car. Started at 9am, didn't finish till after 7pm. Nestah's calm and experienced approach was impressive, every issue had a solution. Work was always clean and precise, never rushed or forced. Fun experience, but maybe I'll stick to my day job.
Dobinson@Springs - C59-185 2” UP TO 440LBS
Dobinson Diff Drop
Airbags - Firestone 4164
Delta VS Panhard Drop Bracket
Fixed Front Sway Bar Link (extra)
Greased Drive Shaft(extra)
Now that the suspension is properly tuned, the truck drives the way it should — smooth, planted, no wiggle over bumps, no sag, no pulling left or right. Straight and confident on the road.
Feels good when everything comes together
Installed parts:
Rear:
Dobinson Diff Drop
