suspension decisions
Tucson, AZ
I have been doing a lot of research using these threads and and slee's site. I was leaning towards the 2.5 ome lift but then worry about not being happy with it as far as hight goes...kind of like when I got my first bike it's was 250cc and with in a month I was wanting a 600-750.
If I go with slee's 6" bolt on kit will I be starting down the road of never ending tweeking to get the 80 to handle well on the freeway and on long trips. side note, why only one double cardan drive shaft in the kit?
I'm going for the expedition style mods on the truck not really into rock crawling. is the 6" overkill? I really like the look of it that high but I don't want to sacrafice long range driveablitiy.
IMOP- 6" is overkill for my definition of expidition wheeling. I think the 4" would be better suited if you're plan is to run 35's.
I don't know that it drives any worse - as long as you don't have vibes due to angle issues shouldn't be a problem. 6" of lift is certainly not arbitrarily too much for a rig this size. You only have one DC shaft because you don't need to correct caster in the rear and that driveshaft is long enough to run smooth with regular u-joints - you just get the adjustable upper arms to set your angles properly.
What 6" of lift wil do, however, is make 35" tires look small, so if you do it you'll want those 37's...and then you are out of the box a bit on axle strength and other areas.
4" of lift and 35's is a great look and well set up for "expedition wheeling" over mall concrete parking lot stops :D
cool thanks I was thinking about 4" and 35's as a happy medium. This also saves $ for mods.
WOW...IMO, this isn't just a matter of 2.5" vs 6" lift. You are getting into a totally different realm. I drove an 80 with the 6" lift and 37s on it several months back. I decided (at that time) that it was way more than I wanted for a DD. It looked killer yes, but didn't fit my plans.
In talking to the owner of the rig he stated he started with the OME 2.5" lift, then the Slee 4", and then on to the Slee 6" lift (with some changes in between like medium to heavy to Js etc). He preferred the OME 2.5" and the Slee 6" over the 4" lift and had better luck ridding the rig of driveline vibrations on these two.
All that aside, going to the Slee 6" lift is way more involved than the OME 2.5" lift so think long and hard what your overall plans are for the rig. As Nay mentions, when stepping up to the 6" lift 35s will look small so then you'll want 37s. Stepping up to 37s now you definitely need to address gearing etc.
FWIW, the 33s on my LX looked HUGE on the rig with the stock suspension. With the OME 2.5" the 33s now look just about right, maybe just a tad small :rolleyes:. I NEVER thought I would go up to 35s but now I'm not so sure.
Price out everything that would be required to step up to the Slee 6" lift (ask Christo what you would need to do above and beyond just the lift) and make sure you know what you the cost is ultimately going to be. Lift price difference alone is what, about $3000 different (not installed)?
The safest/cheapest/least involved is the 2.5 with 33's.
I really don't want to have to deal with re-gearing anytime soon. I knew that there must be a lot of other things that you had to take into account on the 6" lift.
I guess I should go with my first gut reaction and do the 2.5 and 33" it really seems to be the kit that is most user friendly and less likely to give me issues.
All right guys you've talked me down from my grandiose 6" lift idea.
Not as though i don't have 10K worth of other mods to be thinking about also.:idea:
:beer::cheers::flipoff2:
This is taken from my ROTW writeup.
OME 850-J springs in the front with OME 4” Comps in the rear. OME Shocks, N73 front & N74E in back and OME steering stabilizer with OME castor correction complete. Originally, I went with the standard OME 2.5” but with all of the weight that I eventually put in the beast, they were simply not enough as I wore ¼ of my rear flares off during a journey through Sonora, MX. If you look here https://forum.ih8mud.com/showthread.p...ight=Surf+turf at the first pic, you can see why I had to go higher.
Take a look at frankie's off road 3" lift, better IMHO bilstein shocks than the OME L's.
I personally think gearing is better on 35's, because you can click off overdrive and run @ 70 mph @ 3,000 RPM. 33's are more of a no-man's-land for the shift points of the auto transmission. These pics are on 35's with stock gears @ 8,000-10,000 ft. elevation. I want lower gears at some point, but the pictures tell the story.
I would go straight to 35's. 33's do not satisfy on the 80 and buying OME 2.5" and 33's is probably going to mean selling OME 2.5 and 33's at 50 cents on the dollar in about 6 months. You can do 35's on a ~3" lift (the FOR 3" kit is designed for this), but I will caveat that I don't have flares, and so my wheel well openings are bigger. I could run 36's on my setup.
Here you can take a look at this setup. Completely different rig on the FOR suspension with 35's. Not even in the same class. That first pic obstacle spanked a TJ on 38's with a 4:1 low range and the 3rd Gen Runner on 33's with a crawler wouldn't even try it (pic is much steeper and worse than it looks - that's at the top after a 3 foot wheelstand). I wouldn't have touched this on OME 2.5 and 33's, as evidenced by the double strap/winch extraction required in the last pic.
