surging
Chesterfield, VA
My truck started surging from the take off. Runs fine at speed and idols fine. It start after I put 35's on. Stock gears. Would the tires do this? I do not know why.
instead of a steady increase in rpms as you push the gas pedal, the rpms go up and down(cuts out) until it changes to 2nd gear. After it reaches 2nd gear it runs fine. Passes fine ect. No miss at cruising speed at all.
What year truck? Have you tried locking the center diff in high and see if it does this? Does it do it in low? Have you looked for common causes (dizzy, spark plug wires, cracked intake, old spark plugs, etc)?
Does it with center diff locked in high and low(Put in switch). New spark plugs, wires, cap rotor, new fuel filter, clean plenium and injectors. Most vacumn hoses are new. Can't find a vacumn leak. No crack in intake. It is a 97 with a 120k miles.
