Out in the Anza desert - Sheep Canyon this past weekend. Fridge running off the 2nd battery all weekend. Had started the truck Saturday late afternoon comparing 'engine whine' with other 80 owners that had arrived. We noticed the solonoid click on and off several times while the engine was running. It's the only time I started the truck from when we parked late Friday afternoon and it was easily in the 90's during the day Saturday.
I know the Surepower separator designed to separate the two batteries depending on voltage readings and is a set it up and leave it alone type of separator which I wanted (no swithes, etc. to manually connect/disconnect or orveride the system type of separator), but I've never notice it click on and off this many times in the frequency that it did. To cut to it, the next morning I couldn't start the truck at all! Main battery was at 10 volts and the 2nd battery at 8. Starter clicked just fine the first couple of key turns and then nothing after that at all! Dash lights were on.
Quick jump by SoCalFJ and I was off and running.
Do these solonoids go bad? It was installed in 2007.
battery is starting to act up after only 3 years. It's also a Die Hard. When it goes, I'm replacing with the Sears PM-2, I've been very impressed with the PM-1 sitting in my truck.
I've got the 1314-200.
