- Joined
- Feb 24, 2010
- Threads
- 2,226
- Messages
- 2,226
West Monroe, LA -*Superlift’s 2″ and 4″ JK kits now cover 2012 models. Because the new engine configuration causes the stock front driveshaft to bind at full droop on lifted JKs, Superlift includes a front limiting strap. The single limiting strap’s positioning is toward the axle’s center, so very little articulation is lost. Install an [...]
West Monroe, LA -*Superlift’s 2″ and 4″ JK kits now cover 2012 models. Because the new engine configuration causes the stock front driveshaft to bind at full droop on lifted JKs, Superlift includes a front limiting strap. The single limiting strap’s positioning is toward the axle’s center, so very little articulation is lost. Install an aftermarket CV-style driveshaft then remove the strap to restore full travel. Also new is a third shock option: The Fox 2.0 Performance Series IFP (shown) joins the existing base Superide twin-tubes and premium SS monotubes by Bilstein. Superlift’s 4″ kit uses application-specific pre-set coil springs to clear up to 35×12.50 tires with no other modifications. An adjustable front track bar is included. A weld-on relocation bracket is standard for the rear track bar; a bolt-on bracket is also available. Use Superlift’s 2″ coil spacer lift kit to economically fit 33×12.50 tires. Many options and upgrades are available.
For more information, contact Superlift Suspension Systems,*800-551-4955,*www.superlift.com.
Link
West Monroe, LA -*Superlift’s 2″ and 4″ JK kits now cover 2012 models. Because the new engine configuration causes the stock front driveshaft to bind at full droop on lifted JKs, Superlift includes a front limiting strap. The single limiting strap’s positioning is toward the axle’s center, so very little articulation is lost. Install an aftermarket CV-style driveshaft then remove the strap to restore full travel. Also new is a third shock option: The Fox 2.0 Performance Series IFP (shown) joins the existing base Superide twin-tubes and premium SS monotubes by Bilstein. Superlift’s 4″ kit uses application-specific pre-set coil springs to clear up to 35×12.50 tires with no other modifications. An adjustable front track bar is included. A weld-on relocation bracket is standard for the rear track bar; a bolt-on bracket is also available. Use Superlift’s 2″ coil spacer lift kit to economically fit 33×12.50 tires. Many options and upgrades are available.For more information, contact Superlift Suspension Systems,*800-551-4955,*www.superlift.com.
Link
