How were the pic taken? On a ladder or porch looking down?.I have never seen a supercharger on a 3b yet.... interesting.
Wow thats sweet I have never seen a supercharger on a diesel. Is it factory
It's fine if you want something different.
But a turbo will give you more power and better fuel economy for the same load on the engine...What's that aircleaner setup off?
The only thing I can see wrong is using PVC plumbing fittings. They shatter when broken and the bits can be sucked in(another good reason why snorkels shouldnt be made from PVC fittings).Is it common to supercharge a 3B?
And does anybody have any comments about the wisdom of this supercharger fitment below? (The owner says it "has a 4agze supercharger running about 6 pounds boost".)
Having constant compression from the supercharger at low rpms gives cleaner emissions ,ideal in the worlds traffic jams
The other thing is the drive belt seems a little small compared to other SC belts.................................................
Hi Tom,
What would you consider "cheap" for an unmolested 3B? There have been quite a few 3B powered cruisers for sale on Trademe over the past year or two adn I have seen a couple of 3Bs at about $NZ800-1000. What I haven't seen is a 13BT with a manual transmission....
Dave
These are my feelings exactly about the quality of "the install" Rosco.
(I don't think the owner liked the idea of using PVC either because it is used only for a very short section. And I suspect the supercharger isn't doing a lot of work at "6psi boost" anyway.)
