Super simple Hub install question...
Bozeman, MT
Howdy-
I got some new hubs for my 76 fj40 to replace the drive plates that came stock... thanks Poser!
Question, do I need to keep the snap ring on the end of the axle stub? I have a little time late tonight to swap them in before the morning.
Any tips on getting them in would be great. Looks pretty straight forward. It looks like
I take off the drive flanges
remove the snap ring on the shaft,
slide the new hub on... with new gaskets
Replace the snap ring?
Then bolt up the dial and end cap?
Thanks for any help and tips.
Rezarf <><
yes snap ring needs to remain, holds birf in place, and thus aligns inner axle seal surface.
Take the hub apart, slide inner hub onto birf after you apply small amount of like oil, like 30 wt, put snap ring on, put outer hub on
5 min job per side.
there is a badass snap ring tool that snap on has for those bastards, but I just use normal snap ring pliers or 2 screw drivers.
best tool for job
pretty sure I have seen a cheepy knock off at ace, need to pick on up to save hassels
Yoda said:
Yup, snap ring stays. Do I win a drive plate?
Sorry, keep most stuff for spares...
Thanks guys.
Rezarf <><
Got them on. Took about the same amount of time to warm up my frozen pizza as putting them on. Thanks guys.
Rezarf <><
