- Joined
- Dec 24, 2003
- Threads
- 136
- Messages
- 3,559
Fine folks,
I'm trying to track down a damn irritating suspension shake that seems to show up on me only when the temperature's super cold. It almost feels like a shock absorber bolt is loose or perhaps like a sway bar bolt is loose. I have checked those and also all the bearings right after pulling the rig in from outside and everything seems tight. Any suggestions on where to look, do the body mount bolts show some slack as the rubber there shrinks from the cold, how about all the various bushings - do they somehow shrink enough to shake rattle and roll only when it is cold? Thanks.
Add On: The shake only occurs on bumps, this is not a steering shimmy shake. It is one or two after bumps after the original bump and it feels like something's slopping around within its regular range of motion. Hope that helps.
