Wanted sunroof trim 1996 FZJ80
CHARLESTON WV
I just need the front piece that goes on the front edge tan/oak across from driver to passenger but if somebody has the whole set I will take that as well. let me know if you have something
doug
I am going to look at a wreck this next week, it has tan interior so I will look and pull it if its there.
CS
sweet, I forgot to take a pic, but I can this evening after work if you need it to identify it better
The trim around the headliner? This is what I have available..
@LAME - no sir, I need the hard plastic piece of the actual assembly that slides back, I will try to get a pic in a bit im getting ready to mow grass
@schradec - I cant tell for sure, if #4 is a plastic oak/tan piece that spans the front from left to right, then yes, as above in a few I will get a pic .
I was cruising around yesterday and noticed mine was cracked on the passenger edge, don't even know how it cracked as it doesn't touch anything open or closed
Mine did the same too. Just cracked and fell off one day when opening the sunroof. Snap a pic I am going to try and go this week.
here are the pics and I believe it is #4 I need
***Edit** After looking closer I'm 99% sure it won't match yours.
I've got a set of tan. This stuff is getting very hard to find because it all does what yours has done. Or when you try to remove it shatters. Somehow this stuff came off without issue. $100 shipped for the set.
I'm not sure what color it is. My interior was gray so this might not work? It super faded.
so it was gray?, let me try and remove mine, I thought mine was tan, is there a 3rd color? oak or jus the two colors? that definitely is a lot lighter than what I have
