Sunroof help
Holly Springs, NC
I love my sunroof. However lately it is driving me nuts. The "wheel" or bushing on the passenger side, the one that commonly flat spots, finally disintegrated. This is turn is causing the sun roof to jump or flap while driving due to either air pressure or bumps in the road. I could not get an accurate measurement of the bushing since it was in pieces so I used some vacuum line to replace it. The OD of the vacuum line was too large so I turned down the OD with a drill and a file to match the channel . The ID was perfect and seated on the stud nicely. The vacuum line worked incredibly well for months. Regardless, the vacuum line fix has failed. The sunroof is starting to jump and flap again.
Does anyone have specs on the bushing? I'm pretty sure my driver's side bushing is in just as rough shape as the passenger side. New bushing would keep the sunroof tight to the roof line and eliminate the constant noise.
One thing I've heard is that 80 sunroofs don't actually fail very often. So, I doubt you're going to get a useful response. I'd suggest finding an entire donor sunroof from a wrecking yard or 'mud classifieds.
This would be valuable information in another 10 - 20 years when all the donor rigs have dried up, though, so I encourage you to find out the correct bushing diameter. :)
Are you talking about the collars (90387-10108) and grommets (90480-16019) at the front of the pan?
I should have taken a picture :(
The "bushings" are the rollers in the rails on the sides of the sunroof. Overtime they flat spot from wear. Once they flat spot, the sunroof has a half inch of vertical play while in the closed position. I've got some calipers so I might pull the sunroof out and measure the channel and the post.
I know what you're talking about now. Those are small little things.
If you're pulling them off, measure them up and we can get Johnny to make up a couple of dozen sets with his new high-speed, low drag lathe. ;)
